Alphacool Core Geforce RTX 5080 Suprim + Vanguard with backplate
- Article no.: 10265
- EAN: 4250197102650
- Weight: 1,591 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- MSI GeForce RTX™ 5070 Ti 16G Vanguard SOC
- MSI GeForce RTX™ 5080 16G SUPRIM LIQUID SOC
- MSI GeForce RTX™ 5080 16G SUPRIM SOC (MS-V531 VER:2.0)
- MSI GeForce RTX™ 5080 16G Vanguard SOC (MS-V531 VER:2.0)
- MSI MSI GeForce RTX™ 5080 16G EXPERT OC (G5080-16EC)
| Technical data cooler | |
| Dimensions total (L x W x H) | 181,50 x 161,03 x 34,19mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 8 |
| Color | transparent |
| Dimensions (L x W x H) | 181,50 x 132,50 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
