Alphacool Core 140mm fan PWM 3200rpm (140x140x25mm)
- Article no.: 24847
- EAN: 4250197135917
- Weight: 0,195 kg
Alphacool's Core 140mm is a quiet and efficient fan with a wide control range up to 3200 rpm. The PWM controllable fan is not only suitable as a fan on CPU coolers or radiators. Due to its excellent performance values (throughput & static pressure), it can also be used as a case fan. The double-bearing fan axis is smooth running and enables a long service life as well as quiet operation. If you are looking for a powerful fan without aRGB illumination, you will find it in Alpacool's Core 140mm model!
Connections
The fan is controlled via a 4-pin PWM connector. The cable is 40cm long. This allows the fan to be connected directly to the motherboard or a dedicated controller without the use of additional adapter cables or extensions.
Control range
The fan can be controlled from 0 to 3200 rpm via the 4-pin PWM connector. At maximum speed, it allows an airflow of 153.9 CFM combined with a high static pressure of 6.99 mm/H2O. This makes the fan perfect for mounting on radiators of a water cooling system or for ventilating a case.
Technical data | |
Dimension (L x W x H) | 140 x 140 x 25mm |
Material | synthetic material (PBT UL94V-0) |
Bearing Type | Two Ball Bearing |
Rated Voltage | DC 12V |
Operating Voltage | DC 7-14V |
Start-up Voltage | 7V |
Rated Current | 0.66 (Max: 0.75) A |
Rated Power | 7.92 (Max: 9.00) W |
Rated Speed | 0 - 3200 rpm ±10% |
Max. Air Flow | 153.9 CFM |
Max. Static Pressure | 6.99 mm/H2O |
Noise level | 51.0 (Max: 53.0) dBA |
Life Expectance | 70000 h at 40 degrees celcius |
Connection | 4-Pin PWM |
Speed Control Mode | via PWM |
Operating Temperature | -10~+70 degrees celcius |
Other Features | Tachometer Output, Auto Start, Soft Start, Waterproof Level IP22 |
Air flow rate: | 153.9 CFM |
Pressure: | 6.99 mm H2O |
Color Frame: | Black |
Rated speed: | 3400 U/min |
Color Rotor: | Black |
Nominal voltage: | 12V DC |
Size: | 140mm |
Volume: | 51 dB(A) |
Volume range: | 50 - 69,9 dB(A) |
Starting voltage: | 7V |
Lebensdauer (bei 25°C): | 70.000 h |
Power connection: | 4Pin |
Dimensions: | 140 x 140 x 25mm |
