Alphacool Eisbaer Aurora LT Solo - Black
- Article no.: WAC
- EAN: 4250197130660
- Weight: 0,537 kg
The Eisbaer Aurora LT Solo combines CPU cooling block, reservoir and pump in one product. The low construction height allows flexible use in a wide range of scenarios. Especially in small cases with little space, the Eisbaer Aurora LT Solo can convince. The product is also used as the basis of Alphacool's popular AiO water coolers.
Radiator & Pump
As with all Alphacool products, the radiator base is made of nickel-plated copper and is equipped with very fine cooling fins that are distributed over the entire base. A nozzle plate provides an accelerated flow over the cooling fins which increases the cooling performance. The water flow is optimized so that all areas of the cooler base are cooled evenly. The Eisbaer LT Aurora cooler uses the very compact and small DC-LT 2 pump. It provides enough power to add another component such as a GPU water cooler or another radiator to the circuit.
Full Digital aRGB Illumination
The cooler pump assembly and fans are fully equipped with Digital RGB LEDs, also known as addressable RGB or aRGB. Extensive effects can be set with the included controller or a Digital RGB controller on the motherboard. For a nice visual effect, of course, the illuminated polar bear on the cooler pump unit. For easier control via a controller, the fans and also the pump can be connected in series as a daisy chain. This enables a neat wiring of the individual LED components.
AMD: AM2 / AM2+ / AM3 / AM3+ / AM4 / AM5 / FM1 / FM2 / FM2+ / SP3 / SP6 / sTRX4 / sWRX8
Intel: LGA 1150 / LGA 1151 / LGA 1155 / LGA 1156 / LGA 1200 / LGA 1700 / LGA 2011 / LGA 2011-3 / LGA 2066 / LGA 755
Technical data cooler with pump | |
L x W x H | 69 x 69 x 45mm |
Material cooler bottom | nickel plated copper |
Threads | 2x G1/4“ (+ 1x Fillport G1/4“) |
Pump type | DC-LT2 |
Head of delivery | 1 m |
Maximum flow | 72 L/h |
Voltage | 6-13,5V DC |
Power consumption | 3,2W |
Pressure tested | 0,8 Bar |
Maximum working temperature | 60°C |
Material Deckel: | Acryl |
Anschluss: | 2x G1/4“ (+ 1x Fillport G1/4“) |
Abmessungen (L x B x H: | 69 x 69 x 45mm |
Sockel: | AMD AM3/AM3(+), AMD AM4, AMD AM5, AMD SP3, AMD SP6, AMD sTRX4, AMD sWRX8, Intel 115x, Intel 2011(-3), Intel 2066, Intel LGA 1200, Intel LGA 1700, Intel LGA 1851 |
