  • 15360
  • 4250197153607
  • 0,018 kg
WAGZ Alphacool GPX SLI Connector Dual - Acrylic - Addressable RGB - 3 PCI-E Space EOL
€9.98*
Terms and Conditions Alphacool Eisball Digital RGB - Acrylic (D5/VPP Ready)
€78.98*
13324 Alphacool Eisball Digital RGB - Acryl D5 with VPP Apex PWM pump
€125.98*
KAB Alphacool connection cable 3Pin to 3pin Digital RGB - 15cm
€1.48*
The next era has begun and it's called ARGB! For everyone who wants to take their modding to the... more
The next era has begun and it's called ARGB! For everyone who wants to take their modding to the next stage. The Alphacool Aurora Eiscontrol ARGB controller.
Tailored to you
Make your system unique. With the Eiscontrol for Addressable RGB you can control all ARGB LED products directly in different modes. Whether you like it simple or with lots of bling-bling, the limits of what is possible are dissolved here.
Compact and simple
Small but mighty! It fits anywhere, doesn't attract attention and yet has almost unlimited possibilities. Different modes, individual speeds, constant color modes or simply all colors together. You decide what happens in your case. Thanks to the three easy-to-use buttons, the Aurora Eiscontrol doesn't require any technical knowledge. The power supply is universal with a SATA connector and can be operated via any power supply.
  • Connection: SATA
  • Output: 2x 3Pin ARGB (5V)
€1.48 *
€28.98 *
€2.78 *
€1.68 *
€6.49 * €8.98 *
