Alphacool GPX SLI Connector Dual - Acrylic - Addressable RGB - 3 PCI-E Space
  • 12940
  • 4250197129404
  • 0,195 kg
€9.98 * €30.88 * (67.68% Saved)
€15.98*
Connect your graphics cards with the new Alphacool GPX SLI connector and combine all their... more
Connect your graphics cards with the new Alphacool GPX SLI connector and combine all their power! You get the perfect performance thanks to the serial water flow.
ARGB – keep control of your lighting
Illuminate your system as you wish. Thanks to addressable RGB, you retain full control over your lighting. The ARGB LEDs shine in rich, strong colors through high-quality acrylic glass. They can be easily controlled using the Alphacool Aurora Eiscontrol.
Assembly – easier than ever
Thanks to the ¼'' thread, assembly is simple using the connectors included in delivery. Simply install these in your Alphacool Eisblock GPX cooler and plug the Alphacool GPX SLI connector onto them. Thanks to the double-secured O-ring, you can even plug them onto coolers that are already installed.
Extend the system – make it YOUR project
The Alphacool GPX SLI connectors are compatible with all new models of the Alphacool Eisblock series from 2080/2080Ti M02. All previous models can be easily upgraded using the Alphacool GPX SLI Upgrade Kit (1015976) .
The SLI connectors are available in 3 PCI-E Space and 4 PCI-E Space.
  • Dimensions (WxDxH): 58 x 93.96 x 23mm
  • Net weight: 195g
  • Working temperature: Max. 60°C
  • Voltage: 5VDC
  • Certificates: CE, FC, ROHS
Scope of delivery
  • 1x GPX SLI Connector Plexi aRGB X3
  • 4x SLI adapter G 1/4“
Download assembly instructions here
Product data sheet available for download here
€26.98 *
Content 4 Stück (€5.00 * / 1 Stück)
14%
AGB Alphacool Rise Flat Reservoir DDC EOL
€89.98 * €104.98 *
€27.98 *
€1.98 *
