Alphacool ES GPU Terminal 90°
- Article no.: 5100418
- EAN: 4070201004189
- Weight: 0,155 kg
The Alphacool ES GPU Terminal 90° enables space-saving and flexible integration of compatible GPU water coolers into existing water cooling systems.
The 90° angled design optimizes tubing routing, making installation particularly easy in server cases and workstation PCs, where available space is often limited.
The terminal is made of high-quality chrome-plated brass and offers excellent resistance to scratches and chemical influences. Its robust construction ensures long-lasting and reliable use.
The Alphacool ES GPU Terminal 90° is compatible with ES, Core, and Eisblock GPU water blocks whose terminals are secured to the cooling block with three screws, as specified in the compatibility section of the datasheet. Installation must be carried out according to the instructions.
ES GPU waterblocks with a terminal secured to the cooling block using three screws.
Core GPU waterblocks for the Geforce RTX 50XX and Radeon RX 90XX series.
All Eisblock GPU waterblocks.
Compatibility requires the terminal to be secured to the cooling block with three screws.
| Technical data | |
| Dimensions (L x W x H) | 82.50 x 19.00 x 22.00 mm |
| Material terminal | Chrome-plated brass (CuZn39Pb3) |
| Threads | 2x G 1/4 |
| Material connection thread | Chrome-plated brass (CuZn39Pb3) |
| Maximum torque G 1/4 thread | 1.00 Nm |
| Maximum operating temperature | 60 °C |
| Minimum operating temperature | -20 °C |
| Maximum tested pressure | 2.00 bar |
| Recommended working pressure | 0.00-1.00 bar |
