Alphacool NexXxoS HPE-30 Full Copper 560mm Radiator
  • 14471
  • 4250197144711
  • 1,549 kg
  • 10
€173.98 *
€62.98*
€19.98*
€18.98*
€31.98*
12948 Alphacool Eisblock XPX Aurora Edge - Acryl Black Digital RGB
€59.98*
13056 Alphacool Eisblock Aurora Acryl GPX-N RTX 3090TI Founders Edition with Backplate
€49.99*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H596.5 x 144 x 30 mm (±3 %)
Quantity of cooling channels16
Material threadsbrass
Threads4x G 1/4 IN/OUT & 1x Fill-/Drainport G 1/4 (max. 5 mm thread length)
Possible fan size140 mm
Possible fan assembly4x one-sided / 8x both-sided
Thread size fan mountingM3
Pressure tested0.8 bar
Fin density18 FPI
Weight1225 g
Warranty: 10 years
€2.58 *
€4.48 *
€3.47 *
€5.28 *
€34.98 *
Alphacool M3 spacer 34mm
€3.98 *
€27.98 *
