Phobya Y-Kabel 3Pin Molex auf 3x 3Pin Molex - Schwarz 60cm
  • LK
  • 4049469126339
  • 0,019 kg
€4.48 *
Content: 60 Zentimeter (€7.47 * / 100 Zentimeter)
For connection of three 3-Pin fans (radiator fans, case fans etc.) to one Mainboard connector... more
For connection of three 3-Pin fans (radiator fans, case fans etc.) to one Mainboard connector (3-Pin). Please note that rpm monitoring is possible for only of the connected fans.
Sleeving:
The idea behind these cables:
A white sticker on one of the cables shows which fan can be monitored.
Technical specifications:
Connectors: 3-Pin to 3x 3-Pin Y-cable
Colour: Black sleeve, black connectors, black heatshrink
Dimensions: 60cm each
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 3Pin Molex to 3x 3Pin Molex 60cm - black
Please note: When using this adaptor cable please always consider the limitations of the socket from which it draws power. To high currents and loads caused by the connected fans may damage the connected devices!
This product has been reviewed for you:
Aquainfos
Tech-Review
Bauform: Y-Kabel
Hersteller: Phobya
Sleeving: schwarz
1. Seite: 1x 3Pin
2. Seite: 3x 3Pin
Hint!
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
Hint!
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
€5.68 *
Hint!
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
Alphacool tubing AlphaTube HF 16/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
ROH O-Ring für Laing D5/Alphacool VPP655/VPP755
O-ring for Laing D5/Alphacool VPP655/VPP755
€2.09 *
PUM Alphacool VPP655 - Single Edition
Alphacool VPP655 - single edition
€69.98 * €79.98 *
LK Phobya 3er Set 3Pin Verlängerung 80cm
Content 80 Zentimeter (€5.60 * / 100 Zentimeter)
€4.48 *
LZ Lüftergitter für Axiallüfter für 92mm schwarz
Fan grill for axial fans for 92mm black
€1.79 *
L14 Alphacool Core 140mm Lüfter PWM 3200rpm (140x140x25mm)
Alphacool Core 140mm fan PWM 3200rpm (140x140x25mm)
€10.98 *
Alphacool Twin LED RGB 30cm - Sleeving black
€5.48 *
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Black (Paracord 550 Typ 3) 330cm
€1.98 * €4.47 *
RAD Alphacool NexXxoS XT45 Full Copper X-Flow 420mm Radiator
Alphacool NexXxoS XT45 Full Copper X-Flow 420mm radiator
€109.98 * €115.98 *
Liefertermin: in 2 - 3 Wochen
RAD Alphacool NexXxoS ST30 Full Copper X-Flow 140mm Radiator
Alphacool NexXxoS ST30 Full Copper X-Flow 140mm radiator
€48.98 * €59.98 *
Hint!
LZ Phobya 4Pin Molex auf 9x 3Pin Splitter EOL
€4.04 *
AGB Alphacool Eisbecher 250mm Acryl Ausgleichsbehälter EOL
Alphacool Eisbecher 250mm Acryl reservoir
€29.99 * €54.99 *
€1.88 *
S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - UV Blau 3m (9,8ft) Retailbox 300cm
Alphacool tub AlphaTube HF 13/10 (3/8"ID) - UV blue 3m (9,8ft) Retailbox
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
Hint!
LK Phobya Verlängerung 3Pin Molex ultra lang -  Schwarz 90cm EOL
Content 90 Zentimeter (€6.09 * / 100 Zentimeter)
€5.48 *
Hint!
LK Anschlusskabel 3Pin Stecker auf 3Pin Stecker mit Tachosignal 32cm
Content 32 Zentimeter (€6.19 * / 100 Zentimeter)
€1.98 *
LZ Lüftergitter für Axiallüfter für 200mm schwarz
€3.19 *
€3.98 *
Hint!
KAB Phobya 24Pin Netzteil Verlängerung Einzel Sleeving - Schwarz 30cm EOL
€2.58 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
€4.48 *
Hint!
L14 Yate Loon D14SH-12 mit Stecker (2300rpm) ( 140x140x25mm ) EOL
€3.63 *
LK Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm
Content 30 Zentimeter (€11.60 * / 100 Zentimeter)
€3.48 *
LZ Lüftergitter für Axiallüfter für 140mm chrom
€2.69 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
SZ Schlauchabschneider Alu Ersatzklinge 3-19mm
€2.59 *
SZ Alphacool Schlauchabschneider Alu 3-14mm
Alphacool tube cutter Aluminum 3-14mm
