Alphacool NexXxoS Monsta 480mm Radiator
- Article no.: 14183
- EAN: 4250197141833
- Weight: 2,726 kg
*1The new Alphacool NexXxos radiators, a name that stands for experience and quality has come to bring a fresh breeze to the radiator market.
Info about the Monsta radiators:
The Monsta radiators, with a thickness of 80mm, are the first of their size on the market. Hence we were just as keen on finding out how they perform as the independent reviewers!
The tests show that it has significantly increased flow rates than thinner radiators. The cooling performance increased greatly with increased fan speed. Sounds normal, but this radiator shows a different performance profile than standard radiators: At 500rpm the Monsta is slightly better than its 60mm brother, but with increasing fan speed the difference increases: At 800rpm the Monsta already performs much better, and at 1200rpm a Monsta radiator is performing almost as well as a 60mm thick radiator with one fan more, at the same fan speed!
This is truly amazing, and all that at this affordable price!
| Technical data | |
| Dimensions (L x W x H) | 522 x 124 x 86mm |
| Quantity of cooling channels | 12 |
| Cooling channels | Copper |
| Color | black |
| Fan thread | M3 |
| Connection | 6x G1/4" |
| Slats | Copper |
| Number of fans: | 4 |
| Thickness | 69 - 100mm |
| Fan size | 120mm |
| Housing | Steel |
| Manufacturer | Alphacool |
| Pressure tested | 0,8 bar |
| Fins per inch | 10 |
