Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Chrome
  • 17470
  • 4250197174701
  • 0,041 kg
€10.98*
S13 Alphacool HardTube 13/10mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€20.98*
€25.98*
SZ Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
€17.98*
€37.98*
17565 Alphacool Eiszapfen Pro 13mm spare parts
€1.98*
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the... more
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
Technical details:
  • Material: Brass
  • Color: Chrome
  • Diameter: 22mm
  • Height: 20mm
  • Thread: G1/4"
  • Thread length: 5 mm
  • HardTube Size: 13 mm
  • Compatibility: PETG, acrylic, brass and glass tubes
  • Weight: 0.023kg
  • Scope of delivery: 1x Alphacool Eiszapfen PRO 13mm HardTube Fitting G1/4 - Chrome
A notice:
Attention: The manufacturer Mayhems points out that Mayhems fluids, especially the Aurora product line, are manufactured and sold exclusively for show and modding purposes. These should not be used in the system for longer than 14 days.
We would also like to point out that Mayhems fluids can damage water cooling products and therefore the warranty of the following manufacturers will be void if you use Mayhems fluids: Koolance, Phobya, Alphacool, Aqua Computer, Watercool
Damage such as: blockages, dissolution of aluminum radiators, destruction of glued containers, etc. are a consequence of the use of Mayhems fluids, but will not be reimbursed by Mayhems. Use at your own risk!
€37.98 *
€20.98 *
€25.98 *
Alphacool HardTube 13mm OD 90° brass 10/30cm chrome
Content 40 Zentimeter (€49.95 * / 100 Zentimeter)
€38.98 *
€23.98 *
