WAK Alphacool Core Geforce RTX 5090 Gamerock + Phantom with backplate
- Article no.: 10259
- EAN: 4250197102599
- Weight: 1,779 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Gainward GeForce RTX™ 5090 Phantom (4878 / NE75090019R5-GB2020P)
- Gainward GeForce RTX™ 5090 Phantom GS (4861 / NE75090S19R5-GB2020P)
- Palit GeForce RTX™ 5090 GameRock (NE75090019R5-GB2020G)
- Palit GeForce RTX™ 5090 GameRock OC (NE75090S19R5-GB2020G)
| Technical data cooler | |
| Dimensions total (L x W x H) | 214,40 x 153,37 x 34,38mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 9 |
| Color | transparent |
| Dimensions (L x W x H) | 214,40 x 124,80 x 6mm |
| Thick backplate without spacers | 3mm |
| Material | Aluminium |
