Alphacool Core Geforce RTX 5070 Reference with Backplate
- Article no.: 10271
- EAN: 4250197102711
- Weight: 1,216 kg
- Inno3D GeForce RTX™ 5070 TWIN X2 (N50702-12D7-195064N)
- Inno3D GeForce RTX™ 5070 TWIN X2 OC (N50702-12D7X-195064N)
- Inno3D GeForce RTX™ 5070 TWIN X2 OC WHITE (N50702-12D7X-195064W)
- Inno3D GeForce RTX™ 5070 X3 OC (N50703-12D7X-195064L)
- MSI GeForce RTX™ 5070 12G INSPIRE 3X OC (G5070-12I3C)
- MSI GeForce RTX™ 5070 12G SHADOW 2X OC (G5070-V532 V1.1)
- MSI GeForce RTX™ 5070 12G VENTUS 2X OC (G5070-12V2C)
| Technical data cooler | |
| Dimensions total (L x W x H) | 149,00 x 124,07 x 34,12mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 6 |
| Color | transparent |
| Dimensions (L x W x H) | 149,00 x 95,50 x 6,00mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
Delivery date: in 5 - 6 weeks
