Alphacool Apex Pro Skeleton Carbon Case
  • 13758
  • 4250197137584
  • 17,314 kg
€999.98 *
€37.98*
€14.98*
14000 Alphacool Apex RAM X4 Water Cooler Black
€71.98*
13823 Alphacool Apex Stealth Metal Power fan 3000rpm matte black (120x120x25mm)
€21.98*
Unlimited freedom with the Alphacool Apex Pro Skeleton. Made from carbon rods and CNC-milled... more
Unlimited freedom with the Alphacool Apex Pro Skeleton. Made from carbon rods and CNC-milled aluminum connectors, this case was specially developed to meet the requirements of water cooling systems. In order not to limit creativity, the Skeleton can be completely disassembled and customized according to your own wishes. The supplied Distro Plate including pre-assembled VPP Apex pump is designed exclusively for this case and enables numerous connection options.
A new level of creativity
The Alphacool Apex Pro Skeleton Carbon case is characterized by a design in which all components are screw-mounted, which allows for extensive modifiability. Equipped with three radiator mounts, two for 360mm and one for 120mm, this case offers ideal conditions for high-performance cooling systems. A GPU bracket and cable included in the scope of delivery allows the graphics card to be mounted vertically. The mainboard tray including cable box can also be positioned flexibly. The smoked glass side panel is another feature that opens up additional design options, as is the freely selectable positioning of the front panel. All in all, the skeleton case allows a great deal of freedom and creative ideas.
Exclusive distro plate
The included Distro Plate with 750ml reservoir offers connection options for CPU, GPU and radiators. The pre-installed Alphacool Apex pump has enough power for complex cooling loops. The connections of the Distro Plate are made of chrome-plated brass, as is usual with Alphacool. By embedding the connections in the acrylic, the problem of possible leaks due to cracking is avoided. Fitted with O-rings, the two connector parts lock together during installation and ensure maximum safety.
Apex Design
The Apex product line from Alphacool represents the highest level of perfection. First-class materials and innovative technologies guarantee a unique premium product. Consisting of real carbon and modular, CNC-milled aluminum connectors, the Apex Pro Skeleton case offers limitless creativity with a unique look. Inside each Skeleton case resides a truly unique creation waiting to be unleashed.
Dimensions (L x W x H)607.50 x 259.80 x 573.00 mm
Weight13kg
MaterialCarbon, aluminum, smoked glass
Mainboard supportATX, mATX, EATX, ITX
PCIe slots (without vertical GPU mount)7
GPU bracketVertical: 2 Slot | Horizontal: 2+ Slot
PCI Express Riser4.0 x16
Drive mount1x 2.5" SSD
Power supply bracketATX Standard
Radiator front/top support120, 240, 360mm
Radiator rear support120mm
Frontpanel USB2x 3.0 Type A
Frontpanel Audio1x audio output | 1x microphone input
Colorcarbon, black
Technical data Distro Plate
Dimensions (L x W x H)155.00 x 63.50 x 486.00 mm
MaterialAcrylic
Volumeapprox. 750ml
Pump compatibilityVPP/D5
Threads9x G1/4“ + 2x Fillport and 1x Drainport
Pressure tested0.8 bar
Quantity digital aRGB LEDs15
Power digital aRGB LEDs5V
Power connection digital aRGB LEDs3-Pin JST + 3-Pin 5V
Colortransparent
Technical data pump
Material pump coveraluminium
Material axleceramics
Connections4-Pin PWM | SATA
Cable lengths4-Pin PWM - 48cm | SATA - 48cm
Starting voltage12V DC
Maximum pumping head4.25m
Maximum flow rate340L/h
Awards & Videos
GHE Alphacool Apex Skeleton Carbon Gehäuse
Alphacool Apex Skeleton Carbon Case
€649.98 *
Delivery date: in 5 - 6 weeks
NEW
GHE Alphacool Apex Benchtable
€499.98 *
WAC Alphacool Core 1 Silver
€34.98 *
€33.98 *
€41.98 *
€37.98 *
