Alphacool Apex Benchtable
- Article no.: 25056
- EAN: 4250197137195
- Weight: 5,396 kg
- Available: Currently there are 8 available
The Alphacool Apex Benchtable combines premium design, maximum flexibility, and a well-thought-out construction. Whether for demanding hardware testing, frequent component changes, or a custom high-end system, the benchtable's design allows easy access to components and offers a wide range of possibilities.
The construction featuring carbon rods and CNC-machined aluminum connectors gives the Apex Benchtable a premium, technical appearance. The combination of materials ensures a sturdy yet lightweight frame. Thanks to its modular design, the benchtable can be completely disassembled.
The Alphacool Apex Benchtable supports ATX, Micro-ATX, Mini-ITX, and E-ATX motherboards, offering broad compatibility with a wide range of system configurations. The benchtable features a mounting bracket for ATX power supplies. The open design ensures easy access to all components.
The Alphacool Apex Benchtable offers flexible mounting options for water cooling components. In addition to accommodating one 360 mm, one 240 mm, and one 120 mm radiator, it also provides a mounting option for a reservoir. This makes the benchtable an ideal foundation for water-cooled test systems and hardware configurations that require frequent component changes.
| Technical data | |
| Dimensions (L x W x H) | 466.86 x 460.86 x 415.43 mm |
| Material tubes | CFRP / carbon |
| Material radiator panels | CFRP / carbon |
| Material corners | Aluminium (AlMg1SiCu) |
| Material motherboard tray | Aluminium (AlMg1SiCu) |
| Supported radiators | 1x 360 mm, 1x 240 mm, 1x 120 mm |
| Supported fans | 6x 120 mm |
| Supported motherboards | ATX, Micro-ATX, Mini-ITX, E-ATX (without Motherboard Backplate) |
| Supported PSU | ATX |
| Front I/O Connectivity Options | 2x USB 3.0 (Type A), 1x audio out, 1x microphone in |
| Color | Carbon, black |
