Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x0.5mm
  • 12451
  • 4250197124515
  • 0,042 kg
€21.98 *
Content: 100 cm² (€0.22 * / 1 cm²)
Fastening: Slightly adhesive
Thickness: 0,5mm
Surface dimensions: 100 x 100mm
Thermal conductivity: 11W/mk
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1mm
Content 100 cm² (€0.35 * / 1 cm²)
€34.97 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 11W/mK 100x100x1,5mm
Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x1.5mm
Content 100 cm² (€0.50 * / 1 cm²)
€49.98 *
€29.98 *
€6.49 * €8.98 *
Alphacool Core thermal pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
€6.99 *
€11.98 *
Alphacool Core double-sided adhesive thermal pad 100x100x0.25mm
Content 100 cm² (€0.07 * / 1 cm²)
€6.99 *
15%
€99.98 *
Alphacool Core thermal pad Soft 9W/mk 100x100x3mm
€49.98 *
Alphacool Core thermal pad Soft 6.2W/mk 100x100x3mm
Content 100 cm² (€0.33 * / 1 cm²)
€32.97 *
Alphacool Core thermal pad Soft 6.2W/mk 100x100x2mm
€24.98 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x1mm
Alphacool Core thermal pad Soft 6.2W/mk 100x100x1mm
Content 100 cm² (€0.17 * / 1 cm²)
Alphacool Ice Layer Ultra Soft Thermal Pad 3W/mk 100x100x1.5mm
€24.98 *
Alphacool EPDM Tube 13/10 - Black 1m (3.28ft) Retailbox
Liefertermin: in 7 - 8 Wochen
Alphacool Eiszapfen screw plug G1/4 - 6pcs Set Chrome
Content 6 Stück (€2.16 * / 1 Stück)
€1.89 *
WÄM Alphacool Apex Soft Wärmeleitpad 14W/mk 100x100x1mm
Alphacool Apex Soft thermal pad 14W/mk 100x100x1mm
Content 100 cm² (€0.70 * / 1 cm²)
€69.98 *
39%
ANF Alphacool ES D-Plug 31,5mm G1/4 AG auf G1/4 AG - Deep Black
Alphacool ES D-Plug 31.5mm G1/4 AG to G1/4 AG - Deep Black
€4.97 * €8.18 *
