Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x0.5mm
- Article no.: 12451
- EAN: 4250197124515
- Weight: 0,042 kg
| Hersteller: | Alphacool |
| Fastening: | Slightly adhesive |
| Thickness: | 0,5mm |
| Surface dimensions: | 100 x 100mm |
| Thermal conductivity: | 11W/mk |
