Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x1mm
  • 12459
  • 4250197124591
  • 0,059 kg
Content: 100 cm² (€0.80 * / 1 cm²)
Liefertermin: in 2 - 3 Wochen
Fastening: Slightly adhesive
Thickness: 1,0mm
Surface dimensions: 100 x 100mm
Thermal conductivity: 14W/mk
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x0,5mm
Alphacool Ice Layer Thermal Pad - 14W/mK 100x100x0.5mm
Content 100 cm² (€0.47 * / 1 cm²)
€46.98 *
€6.49 * €8.98 *
Content 320 Zentimeter (€11.56 * / 100 Zentimeter)
€36.98 *
WAGZ Alphacool Eisschicht Wärmeleitpad - 14W/mK 100x100x1,5mm
Content 100 cm² (€1.20 * / 1 cm²)
€119.98 *
WÄM NVIDIA 30 Series Thermal Pad Replacement set
Liefertermin: in 9 - 10 Tagen
PUM Alphacool Core Flat Reservoir 240 Left mit VPP Apex Pumpe
Alphacool Core Flat Reservoir 240 Right with VPP Apex Pump
€189.98 *
WAC Alphacool Core 1 Silver
€99.98 *
Alphacool Core thermal pad Soft 6.2W/mk 100x100x3mm
Content 100 cm² (€0.33 * / 1 cm²)
€32.97 *
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 15cm
€3.47 *
Alphacool extension JST aRGB 3-pin to 3-pin 15cm
Content 15 Zentimeter (€8.60 * / 100 Zentimeter)
€1.29 *
Alphacool fan cable 3-Pin to 3-Pin extension 30cm
€2.28 *
Alphacool Y-Splitter 4-Pin to 3x 4-Pin PWM 15cm
€2.78 *
€29.98 *
€1.89 *
15%
WAH Alphacool HDX Apex Acetal M.2 2280 SSD Kühler
Alphacool HDX Apex Acetal M.2 2280 SSD Cooler
€30.00 *
39%
ANF Alphacool ES D-Plug 31,5mm G1/4 AG auf G1/4 AG - Deep Black
Alphacool ES D-Plug 31.5mm G1/4 AG to G1/4 AG - Deep Black
€4.97 * €8.18 *
21%
WÄM Alphacool Subzero Thermal grease 20g
€33.97 * €42.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 420mm Radiator
€121.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 280mm Radiator
€93.98 *
Alphacool HardTube 13mm OD 90° Brass 20/40cm Deep Black
Content 60 Zentimeter (€36.63 * / 100 Zentimeter)
€21.98 *
€34.98 *
