Alphacool Ice Layer Thermal Pad - 11W/mK 100x100x0.5mm
- Article no.: 12451
- EAN: 4250197124515
- Weight: 0,042 kg
Fastening: | Slightly adhesive |
Thickness: | 0,5mm |
Surface dimensions: | 100 x 100mm |
Thermal conductivity: | 11W/mk |
Liefertermin: in 2 - 3 Wochen
Liefertermin: in 7 - 8 Wochen
