Alphacool thermal pad for NexXxoS GPX 3W/mk 15x15x2mm orange marked PE Bag (24 pieces)
  • 12198
  • 4250197121989
  • 0,021 kg
€3.78 *
Content: 54 cm² (€0.07 * / 1 cm²)
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 15 x 15 x 2mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
24x Alphacool thermal pad for NexXxoS GPX
Fastening: Slightly adhesive
Thickness: 2,0mm
Surface dimensions: 30 x 30mm
Thermal conductivity: 3,0W/mk
Alphacool Core thermal pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.44 * / 1 cm²)
€6.99 *
Alphacool GPU RAM Aluminum Heatsinks 15x15mm - black 10 pieces.
Content 10 Stück (€0.60 * / 1 Stück)
€5.98 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x0.5mm
Content 16 cm² (€0.25 * / 1 cm²)
€3.97 *
Alphacool Ice Layer Ultra Soft Thermal Pad 3W/mk 100x100x1.5mm
€24.98 *
WAC Alphacool Eisbaer Pro ES (Solo) Full Black
€72.99 *
17%
S16 Alphacool Carbon HardTube 16mm 4x 80cm
Content 80 Zentimeter (€43.71 * / 100 Zentimeter)
€34.97 * €42.00 *
€29.98 *
17%
€14.98 * €17.98 *
WAGZ Alphacool Eisblock Aurora Terminal flat straight - Acetal
Alphacool Silicon Bending Insert 150cm for ID 1/2" / 13mm HardTubes - Blue
Content 150 Zentimeter (€11.32 * / 100 Zentimeter)
€6.99 *
76%
€1.19 * €4.89 *
Alphacool Y-cable RGB 4-pin to 3x 4-pin incl. connector - black 60cm
€2.98 *
WAGZ Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 100x100x1mm
Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x1mm
