Alphacool Eisschicht Light thermal pad - 7W/mK 100x100x1mm
- Article no.: 12858
- EAN: 4250197128582
- Weight: 0,034 kg
Alphacool's ultimate solution lets you cool your computer with a sheet of ice. Not an ice sheet in the conventional sense, made of frozen water, but a sheet that brings every chip down to freezing. The properties of these new thermal pads speak for themselves.
The light version of the Alphacool Eisschicht ("ice sheet") is the "small and weak" version at 7W/mK, but is definitely strong enough. Any hardware components can now be put together neatly and easily with thermal pads.
The Alphacool Eisschicht offers all the benefits and typical qualities of a thermal pad: self-adhesive, elastic, flexible, and much more! Just as varied are the options for placement: whether on RAM or motherboard coolers, or graphics card and CPU coolers, any place where chips meet cooler bodies is a good place for an Alphacool Eisschicht.
The Eisschicht Light, with a performance level of 7W/mK, is available in 0.5mm, 1mm, and 1.5mm thicknesses. Perfect for levelling height differences. Each thickness is also available in 100x100mm and 120x20mm (suitable for RAM coolers) sizes. These can easily be cut with scissors to get the right size for any component.
| Technical data | |
| Dimensions (L x W x H) | 100 x 100 x 1mm |
| Thermal conductivity | 7W/mK |
| Color | pink |
| Hersteller: | Alphacool |
| Fastening: | Slightly adhesive |
| Thickness: | 1,0mm |
| Surface dimensions: | 100 x 100mm |
| Thermal conductivity: | 7,0W/mk |
