Alphacool Acryl Tube outer thread 60x204mm (DxH)
  • 15472
  • 4250197154727
  • 0,286 kg
  • Currently there are 6 available
13339 Alphacool VPP Apex Pump
€79.98*
15394 Alphacool Core 200 Aurora reservoir D5/VPP Acetal/Acryl
€56.98*
€99.98*
Perfect replacement or practical extension. Does your Alphacool Core 100 or Core 200 need a... more
Perfect replacement or practical extension. Does your Alphacool Core 100 or Core 200 need a visual upgrade or a functional adjustment? The replacement acrylic tube with external thread is the ideal solution to give your Core 100 / 200 a new shine or to customize the size.
With the Alphacool acrylic tube external thread 60x204mm you can easily give your water cooling system a new look or expand its functionality. Does your Core 200 no longer look so good because the acrylic tube has become scratched? Or do you have the Core 100 version and want to upgrade to the larger Core 200 version? No problem! This high-quality spare part offers you exactly these options.
Simply unscrew the scratched or too small acrylic tube and fit the new one. You can continue to use the pump base and cover without any problems. This saves you time and effort - with an impressive result! Whether as a spare part or an extension: With the Alphacool acrylic tube external thread 60x204mm you get the best out of your water cooling system
Technical Data
Dimensions (DxH)60x204mm
ColorTransparent
MaterialAcrylic
CompatibilityAlphacool Core 100, Alphacool Core 200
83%
€0.99 * €5.89 *
€3.98 *
€3.47 *
35%
€51.98 * €79.98 *
Alphacool HardTube 13/10mm 90° acrylic (PMMA) 20/40cm
Content 60 Zentimeter (€18.30 * / 100 Zentimeter)
€10.98 *
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
