Alphacool Apex RAM X4 Water Cooler Silver
- Article no.: 13781
- EAN: 4250197137812
- Weight: 0,704 kg
The Alphacool Apex RAM X4 water cooler in combination with the Alphacool D-RAM modules offers maximum cooling performance for your memory. As RAM is becoming more and more powerful, it is advisable to reliably dissipate the resulting waste heat with a RAM water cooler. The Apex optics and digital aRGB lighting ensure a stylish appearance.
High-quality RAM cooler
As modern hardware produces more and more waste heat, powerful and reliable cooling is essential. The Apex RAM X4 with its 3mm thick nickel-plated copper cooler base offers precisely these features. It is optimized specifically for the latest RAM generation. Installation of the Alphacool Apex RAM X4 water cooler is straightforward.
Note: Additional Alphacool D-RAM modules are required for the RAM on which the Apex RAM X4 Water Cooler is mounted. Up to four RAM slots can be covered by this X4 cooler.
Apex Design
The Apex product line from Alphacool represents the highest level of perfection. First-class materials and innovative technologies guarantee a unique premium product. The design language harmonizes perfectly with other Apex products, creating an impressive overall picture.
Digital aRGB lighting
A total of five aRGB LEDs provide discreet but impressive lighting, with each LED individually controllable via a corresponding controller or via the mainboard. This opens up many creative possibilities.
| Technical data | |
| Dimensions (L x W x H) | 127,50 x 45,00 x 17,30mm |
| Material cooler top | Aluminium |
| Material water-bearing components | PMMA (plastic) |
| Material cooler base | Nickel-plated copper |
| Threads | 2 x G1/4“ |
| Power supply Digital aRGB | 3-Pin 5V |
| Quantity digital aRGB LEDs | 5 |
| Pressure tested | 8 bar |
| Weight | 270g |
| Color | black / silver |
Warranty: 2 years
Delivery date: in 6 - 7 weeks
