Alphacool NexXxoS HPE-30 Full Copper 480mm Radiator
  • 14469
  • 4250197144698
  • 1,269 kg
  • 10
€138.98 *
13295 Alphacool Eisstation D5 reservoir with VPP Apex PWM pump
€83.98*
12949 Alphacool Eisblock XPX Aurora Edge - Acryl Chrome Digital RGB
€59.98*
15379 Alphacool Eisbecher Aurora D5 Acetal/Glas - 250mm
€109.98*
11944 Eisblock Aurora Acryl GPX-A Radeon RX 6800/6800XT/6900XT Reference with Backplate
€49.98*
€12.98*
€14.98*
For more than a decade, Alphacool has dominated the market with the NexXxoS Full Copper radiator... more
Connection options & mounting
Safety first
Patented screw plugs
Technical data radiator
L x W x H511,5 x 124 x 30mm (+/- 3%)
Material threadsbrass
Threads4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4" (max. 5mm thread length)
Possible fan size120mm
Possible fan assembly4x one-sided / 8x both-sided
Thread size fan mountingM3
Pressure tested0,8 Bar
Fin density18 FPI
Weight968g
Warranty: 10 years
€28.98 *
€34.98 *
€33.98 *
