Alphacool Eisblock Aurora Geforce RTX 4090 Aorus Master - Gaming V.2 with backplate
  • 13838
  • 4250197138383
  • 1,785 kg
€129.98 * €159.98 * (18.75% Saved)
€19.98*
ANK Alphacool HF quick release coupling set TPV - Eisbaer compatible - Black
€11.98*
€17.98*
13446 Alphacool Core 1 Aurora Black
€119.98*
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics... more
The next generation - the Alphacool Eisblock Aurora water cooler for Geforce RTX 40XX graphics cards. In order to dissipate the enormous heat of this graphics card generation in the best possible way, numerous optimizations have been made to the water cooler compared to the previous model. The fin structure was adapted and enables a very good water flow while increasing the cooling surface. The modified jet plate with improved inflow engine ensures an optimal distribution of the water on the cooling fins.
Technical Highlights
Chrome-plated copper
Design
The Aurora design of the Geforce RTX 40XX Eisblock generation is visually calmer and simpler. Only one O-ring runs around the entire cooler. The design around the cooling fins and jetplate makes for a cleaner look. The illumination of the digitally addressable RGB LEDs is even better distributed throughout the cooler as a result of the chrome plating. The terminal's design is in line with the classic Aurora design.
Thermal paste & thermal pads
Note: This Version (V.2) of the cooler is compatible with PCB Layout V.1.1 and V.1.0
- Gigabyte AORUS GeForce RTX 4090 Master 24G, 24GB GDDR6X (GV-N4090AORUS M-24GD)
- Gigabyte GeForce RTX 4090 Gaming OC 24G, 24GB GDDR6X (GV-N4090GAMING OC-24GD)
Technical data cooler
Dimensions (L x W x H)233,3 x 152,46 x 33,9mm
Material cooler topacrylic
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs12
Colortransparent
Technical data backplate
Dimensions (L x W x H)233,3 x 127,96 x 6mm
Materialaluminium
Warranty: 2 years
Awards & Videos
Cooler type: Complete cooler
Material base plate: Copper;
Material Lid: Acrylic;
SLI compatible: Yes
Dimensions: 233,3 x 152,46 x 33,9mm
Connection: 4x G1/4"
Hardware model: RTX 4090;
Christmas discount
Christmas discount
23%
Christmas discount
Christmas discount
Christmas discount
Christmas discount
Christmas discount
Christmas discount
WAC Alphacool Core 1 Silver
€99.98 *
Christmas discount
€99.98 *
Christmas discount
Christmas discount
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 30cm
€3.97 *
Delivery date: in 9 - 10 days
Alphacool Y-Splitter 4-Pin to 2x 4-Pin PWM 15cm
Content 15 Zentimeter (€11.60 * / 100 Zentimeter)
€1.74 * €2.48 *
Content 60 Zentimeter (€3.13 * / 100 Zentimeter)
€1.88 * €2.68 *
Christmas discount
Christmas discount
€29.98 *
Christmas discount
Christmas discount
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
Christmas discount
€6.28 *
Christmas discount
WZS Alphacool Spritzflasche Core 250ml
Alphacool spray bottle Core 250ml
€4.48 *
Christmas discount
Christmas discount
Christmas discount
Christmas discount
Christmas discount
Christmas discount
Content 2 Stück (€12.99 * / 1 Stück)
€25.98 *
Christmas discount
Christmas discount
Christmas discount
Christmas discount
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - UV White 3m (9.8ft) Retailbox 300cm
Christmas discount
