Alphacool Core Geforce RTX 5090 TUF Gaming with backplate
  • 10269
  • 4250197102698
  • 1,9 kg
€199.98 *
€18.98*
€33.97*
€119.98*
€31.98*
- Asus TUF Gaming GeForce RTX™ 5090 32GB GDDR7 (90YV0LY1-M0NA00)
- Asus TUF Gaming GeForce RTX™ 5090 32GB GDDR7 OC Edition (90YV0LY0-M0NA00)
Technical data cooler
Dimensions total (L x W x H)235,95 x 155,57 x 34,12mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs9
Colortransparent
Technical data backplate
Dimensions (L x W x H)235,95 x 127,00 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
Material base plate: Aluminum
Dimensions: 235.95 x 155.57 x 34.12mm
Connection: 4x G1/4"
Hardware model: RTX 5090
Alphacool Core 1 Aurora Black
€119.98 *
Liefertermin: in 10 - 11 Wochen
Alphacool Eiszapfen 16/10mm screw-on nozzle 90° rotatable G1/4 - 4pcs Set Chrome
Content 4 Stück (€7.00 * / 1 Stück)
€27.98 *
€34.98 *
Liefertermin: in 2 - 3 Wochen
€99.98 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Content 4 Stück (€5.00 * / 1 Stück)
Alphacool Eiszapfen 13mm HardTube screw-on nozzle 90° rotatable G1/4 for acrylic/brass tubes - 4pcs
Alphacool Apex Liquid Red UV-active 1000ml
Alphacool EPDM Tube 16/10 - Black 3m (9.84ft) Retailbox
Liefertermin: in 3 - 4 Tagen
RAD Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
€109.98 *
Liefertermin: in 6 - 7 Wochen
29%
PUM Alphacool Core 100 Aurora Ausgleichsbehälter Acetal/Acryl mit VPP Pumpe
Alphacool Core 100 Aurora reservoir acetal/acrylic with Apex pump
€84.98 * €118.98 *
€33.97 *
