WAK Alphacool Core Geforce RTX 5090 Gamerock + Phantom with backplate
  • 10259
  • 4250197102599
  • 1,8 kg
  • There are more than 5 units available
€199.98 *
€18.98*
€33.97*
€119.98*
€31.98*
- Gainward GeForce RTX™ 5090 Phantom (4878 / NE75090019R5-GB2020P)
- Gainward GeForce RTX™ 5090 Phantom GS (4861 / NE75090S19R5-GB2020P)
- Palit GeForce RTX™ 5090 GameRock (NE75090019R5-GB2020G)
- Palit GeForce RTX™ 5090 GameRock OC (NE75090S19R5-GB2020G)
Technical data cooler
Dimensions total (L x W x H)214,40 x 153,37 x 34,38mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs9
Colortransparent
Technical data backplate
Dimensions (L x W x H)214,40 x 124,80 x 6mm
Thick backplate without spacers3mm
MaterialAluminium
Material base plate: Aluminum
Dimensions: 214.40 x 153.37 x 34.38mm
Connection: 4x G1/4"
Hardware model: RTX 5090
€34.98 *
Liefertermin: in 2 - 3 Wochen
WAC Alphacool Core 1 Silver
€99.98 *
Alphacool fan cable 4-pin to 4-pin extension 30cm
€2.28 *
€6.28 *
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
WZS Spritzflasche 500ml PE-LD
spray bottle 500ml PE-LD
€4.19 *
Liefertermin: in 6 - 7 Tagen
KAB Alphacool Mini USB auf Mainboard USB 5-Pin 40cm
Alphacool Mini USB to Mainboard USB 5-Pin 40cm
Content 40 Zentimeter (€7.45 * / 100 Zentimeter)
€2.98 *
€99.98 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 60cm
€5.28 *
Alphacool Y-Splitter 4-Pin to 4x 4-Pin PWM 15cm
€3.47 *
Alphacool fan cable 4-pin to 4-pin extension 15cm
€1.98 *
