Alphacool Core Geforce RTX 4080 Suprim with Backplate
- Article no.: 13532
- EAN: 4250197135320
- Weight: 7,35 kg
- Available: There are more than 5 units available
- MSI GeForce RTX 4080 16GB Suprim X, 16GB GDDR6X (V511-004R)
- MSI GeForce RTX 4080 Gaming X Trio 16GB, 16GB GDDR6X (V511-005R)
- MSI GeForce RTX 4080 SUPER 16G GAMING TRIO
- MSI GeForce RTX 4080 SUPER 16G GAMING X TRIO
- MSI GeForce RTX 4080 SUPER 16G SUPRIM
- MSI GeForce RTX 4080 SUPER 16G SUPRIM X (V511-248R)
| Technical data cooler | |
| Dimensions (L x W x H) | 269,16 x 153,70 x 31,64mm |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Thickness cooler bottom | 11,3mm |
| Number of digital aRGB LEDs | 15 |
| Color | transparent |
| Dimensions (L x W x H) | 269,16 x 130,70 x 5mm |
| Material | aluminium |
| Color | black |
| Hersteller: | Alphacool |
| Cooler type: | Complete cooler |
| Material base plate: | Copper; |
| Material Lid: | Acrylic; |
| SLI compatible: | Yes |
| Dimensions: | 269,16 x 153,70 x 31,64mm |
| Connection: | 4x G1/4" |
| Hardware manufacturers: | NVIDIA |
| Hardware model: | RTX 4080; |
| Notice: | Compatible up to 16/13mm straight; Compatible up to 19/13mm angled; |
