Yate Loon D80SM-12 with plug (2500rpm) (80x80x15mm)
- Article no.: L80
- EAN: 4049469047573
- Weight: 0,07 kg
New fan from Yate Loon. Strong air flow and whisper-quiet operation characterize this 80mm axial fan with bronze bearing. The fan can be connected to a power supply (with appropriate adapters if not available) or directly to the mainboard via the 3-pin Molex connector. The fan is also ideal for super silent operation at < 7V. Thanks to the extra long connection cable of approx. 60cm, the fan can also be properly wired in larger cases (e.g. server or big tower) without the need for an extension cable.
Technical data:
Dimensions: 80x80x15mm
Supply voltage: 12V
Speed: 2500 rpm
Air flow rate: 24CFM
Noise level: 30dB
Voltage: 0.10A
With 3-pin Molex connector, approx. 60cm cable and speed signal.
Nennspannung: | 12V DC |
LED: | nicht vorhanden |
Lautstärkebereich: | 30 - 49,9 dB(A) |
Stromanschluss: | 3Pin |
Luftförderbereich: | 0 - 49 m³/h |
Größe: | 80mm |
Leistungsaufnahme: | 1,2W |
Hersteller: | Yate Loon |
RPM Signalübertragung: | Nein |
Nenndrehzahl: | 2500 U/min |
Abmessungen: | 80 x 80 x 15mm |
Farbe Rahmen: | schwarz |
Luftförderleistung: | 24 m³/h |
Lautstärke: | 30 dB(A) |
Farbe Rotor: | schwarz |
Liefertermin: in 6 - 7 Wochen
