Alphacool ES Stream LGA 4677 / SP5 LGA 6096 1U
  • 10230
  • 4250197102308
  • 0,561 kg
€132.98 *
The Alphacool ES Stream CPU Cooler was specially developed for powerful processors on Intel's... more
The Alphacool ES Stream CPU Cooler was specially developed for powerful processors on Intel's socket LGA 4677 in server and workstation systems. With the supplied bracket, the Alphacool ES Stream CPU cooler now also supports the SP5 socket from AMD. A new feature is that for the first time the water is distributed over the cooler base via four nozzles. With the help of this nozzle technology, all cores of the processor are optimally covered and thus cooled more effectively and with greater precision. Thanks to the change from one to four nozzles, the ES Stream CPU cooler is able to reliably dissipate waste heat of up to 600 watts.
Performance-oriented!
The cooler base has been optimized specifically for the large processor cores. The four nozzles of the ES Stream are not milled, but naturally incorporated into the cooler. The organic water flow ensures a smooth water flow and thus increases the cooling performance. The entire cooler is made of nickel-plated copper. Copper has almost twice the thermal conductivity of aluminum and is therefore particularly suitable for server or workstation systems.
Optimized for space!
Despite the large cooler base and the four nozzles, the ES Stream is compact and flat. In order to mount the cooler in server racks without any issues, the connections are located on the side to save room.
Thermal paste
The included thermal paste is Alphacool's Subzero with a thermal conductivity of 16 W/mK. The electrically non-conductive Thermal Grease is particularly well suited for high contact pressures, but can still be processed perfectly due to the viscosity of 3,000,000 mPa. s.
AMD: SP5 (LGA 6096)
Intel: LGA 4677 / LGA 4710
Dimensions (L x W x H)118,50 x 75,50 x 20,50 mm
Material cooler topAcetal
Material coolernick plated copper
Cooling capacityup to 600W
Pressure tested8 bar
Max working temperature60 °C
Threads2 x G1/4“
Fin thickness0,4mm
Fin distance0,4mm
Colorblack, silver
22%
€46.98 * €59.98 *
17%
S16 Alphacool Schlauch AlphaTube HF 16/10 (3/8"ID) - UV Blau 3m (9,8ft) Retailbox 300cm
Alphacool hose AlphaTube HF 16/10 (3/8"ID) - UV blue 3m (9.8ft) retail box 300cm
€14.98 * €17.98 *
Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Blue transparent 3m (9.8ft) Retailbox 300cm
Delivery date: in 5 - 6 weeks
€39.98 *
