Alphacool Eiswasser Crystal Yellow UV-active premixed coolant 1000ml
  • 18542
  • 4250197185424
  • 1,1 kg
Content: 1000 Milliliter
S13 Alphacool Ice Tube 13/10mm PETG HardTube 80cm - Set of 4 (320cm)
€23.98*
€19.98*
S13 Alphacool hose AlphaTube HF 13/10 (3/8"ID) - UV Red 1m (3.3ft) Retailbox 100cm
€7.98*
€16.98*
WZS filling aid - plastic funnel
€4.99*
With Alphacool Eiswasser, water cooling pioneer Alphacool is checking off every modder and... more
Note: This cooling liquid does not contain any biocides or anti-corrosion additives. It should also be noted that the loop must be cleaned more frequently when using this colored liquid. The dyes it contains can clog the circuit after a long period of use and impair cooling performance. Alphacool's Eiswasser series is therefore more suitable for use in show cases than in gaming or work PCs.
Content1000ml
SpecificationReady mix
Coloryellow
UV inkyellow
ManufacturerAlphacool
38%
Alphacool Eisblock Aurora Acryl RX 7900XT Reference with Backplate
€99.98 * €159.98 *
SZ Schlauchabschneider
hose cutter
€6.29 *
€3.47 *
