flow indicator with filter G1/4"
- Article no.: 71021
- EAN: 4049469009687
- Weight: 0,018 kg
- Available: Currently there are 3 available - More is on the way
This new flow indicator is used as an optical flow control in the water circuit. The flow of the water sets the wheel in motion, and the rotating impeller shows the flow of the liquid. Malfunctions such as kinked hoses or similar can be visually checked in this way. The filter has not proven to be a hindrance even at high flow rates. The filter catches even the smallest particles in the water circuit. This is very useful if you have a jet cooler in the circuit, as blockages can be almost ruled out.
Technical data:
For connections with G1/4"
Length: 57mm
Diameter: 24 mm
Impeller color: red
Important: The direction of flow must be taken into account. If the filter is dirty, it can be cleaned by backwashing.
Installation note: Tightening the connection too tightly can cause cracks in the acrylic. The tightening torque must not exceed 6Nm.
Note: Due to the vulnerability of the plastic, the use of coolants with chemical additives or colorants can lead to stress cracks. These stress cracks can lead to leaks or breakages.
