Alphacool Eisfluegel flow indicator blue 6-11mm - acrylic
- Article no.: 17356
- EAN: 4250197173568
- Weight: 0,019 kg
Alphacool Eisflügel: The flow indicator with added value!
Water cooling in a computer always serves to improve the appearance. Neatly laid hoses or hard tubes create an impressive image. The Alphacool ice wing can also be used to create a real eye-catcher. The silent rotation of the impeller always shows the direction of flow.
Technical data:
- Dimensions: 88 x 40 x 15mm
- pressure load up to 2 bar, max.
- Connection: for hoses with an inner diameter of 6-11mm.
- Material: ABS
- 1x Alphacool Eisfluegel flow indicator blue 6-11mm - acrylic
