Phobya 4Pin Molex Stromverlängerung - Schwarz 60cm
  • KAB
  • 4049469100810
  • 0,027 kg
€5.68 *
Content: 60 Zentimeter (€9.47 * / 100 Zentimeter)
Liefertermin: in 2 - 3 Wochen
Extension cable for connection of a 4-Pin Molex fan (CPU fan, case fan etc.) to a PSU connector... more
Extension cable for connection of a 4-Pin Molex fan (CPU fan, case fan etc.) to a PSU connector or other fan connector (4-Pin Molex), approx. 62cm long.
Sleeving:
The idea behind these cables:
Technical specifications:
Connector: 4-pin plug to 4-Pin socket
Length: 60 cm
Colour: black sleeve, black heatshrink, black connectors
Extent of delivery:
1x Phobya 4Pin Molex power extension 60cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Extremehardware (it.)
Sleeving: schwarz
Hersteller: Phobya
1. Seite: 1x 4Pin Molex
Bauform: Verlängerung
2. Seite: 1x 4Pin Molex
LK adapter 4Pin (12V) to 3Pin (7V)
€1.19 * €2.09 *
€1.19 *
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
€5.68 *
RAD Alphacool NexXxoS ST30 Full Copper 420mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 420mm radiator V.2
€99.98 *
WZS Alphacool Molex Extractor Kit Pro - Black
€24.98 *
Alphacool Eisrohr 13/10mm PETG HardTube 80cm - 4pcs
Content 320 Zentimeter (€6.87 * / 100 Zentimeter)
€21.98 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 30cm
€4.48 *
LK Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm
Content 30 Zentimeter (€11.60 * / 100 Zentimeter)
€3.48 *
