Phobya Y-Adapter 4Pin Molex auf 4x 3Pin (12V) - Schwarz 30cm
- Article no.: LK
- EAN: 4049469100513
- Weight: 0,023 kg
A Y-cable to connect 4x3-Pin fans to one 4-Pin power connector.
For connection of up to four fans to one 4-Pin Molex power connector. The special feature of this adaptor is the looped-through 4-Pin Molex connector which still allows use of the connector used for connection of the fans.
The extension cable is sleeved with a black mesh which additionally protects the cable and looks great! This further expands the lifespan of the cable. The ends towards the connectors are fixated with heatshrink for a clean finish.
A white marking on one of the split cables shows from which cable the rpm signal is transmitted.
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors:
1x 4-Pin Molex male
3x 3-Pin fan connector female
Colour: Black sleeve, black connectors, black heatshrink
Dimensions: Overall 30cm
Conforms with RoHS
Extent of delivery:
1x Phobya Y-adaptor 4-Pin Molex to 4x3-Pin fan connector (12V) 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
1. Seite: | 1x 4Pin |
Bauform: | Y-Kabel |
Sleeving: | schwarz |
2. Seite: | 4x 3Pin |
Hersteller: | Phobya |
Liefertermin: in 10 - 11 Wochen
