Alphacool Core Geforce RTX 5080/5070Ti GamingPro with Backplate
  • 14741
  • 4250197147415
  • 1,241 kg
€219.98 *
€19.98*
€37.98*
€35.98*
€125.98*
- Palit GeForce RTX™ 5070 Ti GamingPro (NE7507T019T2-GB2031A)
- Palit GeForce RTX™ 5070 Ti GamingPro OC (NE7507TS19T2-GB2031A)
- Palit GeForce RTX™ 5070 Ti GamingPro V1 (NE7507T019T2-GB2031Y)
- Palit GeForce RTX™ 5070 Ti GamingPro-S (NE7507T019T2-GB2031U)
- Palit GeForce RTX™ 5080 GamingPro (NE75080019T2-GB2031A)
- Palit GeForce RTX™ 5080 GamingPro OC (NE75080S19T2-GB2031A)
Technical data cooler
Dimensions total (L x W x H)184,70 x 125,32 x 34,19mm
Material cooler topAcrylic
Material terminalNylon
Max working temperature60°C
Pressure tested0,8 bar
Threads4 x G1/4"
Thickness cooler bottom3,25mm
Thickness cooling fins0,4mm
Distance cooling fins0,4mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5V
Number of digital aRGB LEDs8
Colortransparent
Technical data backplate
Dimensions (L x W x H)184,70 x 96,75 x 6,00mm
MaterialAluminium
€1.78 *
Delivery date: in 2 - 3 weeks
€26.98 *
€34.98 *
€41.98 *
€1.48 *
