Alphacool Core Geforce RTX 5080 Solid + AMP with backplate
- Article no.: 14733
- EAN: 4250197147330
- Weight: 1,666 kg
*1Alphacool introduces its new series of graphics card water coolers for the latest Nvidia GeForce RTX generation. Part of the Core product series, these coolers combine the highest quality with exceptional performance. Thanks to an optimized technical design, these GPU coolers deliver outstanding cooling performance.
- Zotac Gaming GeForce RTX 5070 Ti AMP Extreme Infinity (ZT-B50710B-10P)
- Zotac Gaming GeForce RTX 5070 Ti Solid OC (ZT-B50710J-10P)
- Zotac Gaming GeForce RTX™ 5080 AMP Extreme Infinity (ZT-B50800B-10P)
- Zotac Gaming GeForce RTX™ 5080 AMP Extreme Infinity Ultra (ZT-B50800BU-10P)
- Zotac Gaming GeForce RTX™ 5080 Solid (ZT-B50800D-10P)
- Zotac Gaming GeForce RTX™ 5080 Solid OC (ZT-B50800J-10P)
| Technical data cooler | |
| Dimensions total (L x W x H) | 235,60 x 150,57 x 34,10mm |
| Material terminal | Nylon |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 11 |
| Color | transparent |
| Dimensions (L x W x H) | 235,60 x 122,00 x 6mm |
| Thickness backplate without spacers | 3mm |
| Material | Aluminium |
