Alphacool Core Wind 240mm ST30 water cooling Set
  • 11984
  • 4250197119849
  • 4,52 kg
€119.98 * €199.98 * (40% Saved)
17464 Alphacool Eisfluegel Aurora flow indicator "HighFlow" with RPM-Signal
€38.98*
17576 Alphacool Core temperature sensor G1/4 IT/IT with C/F Display - deep black
€24.98*
€12.98*
14440 Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
€121.98*
13395 Alphacool ES Geforce RTX 4090 Reference Design with Backplate
€69.98*
With the Core Wind water cooling kit, Alphacool provides all the components needed to get... more
With the Core Wind water cooling kit, Alphacool provides all the components needed to get started in the world of water cooling. The set is aimed not only at beginners, but also at enthusiasts. The selected components are optimally matched and come from Alphacool's DIY program. The choice of materials is still uncompromisingly based on copper or brass for all metals in order to guarantee performance-oriented CPU cooling. Due to the included quick-release fastener, additional components like radiators or GPU coolers can be integrated afterwards without having to drain or rebuild the water loop.
Eisblock Aurora XP³ Light CPU-Cooler
With the Eisblock Aurora XP³ Light you get a very compact CPU water cooler for all common mainstream sockets from AMD and Intel. The nickel-plated copper cooler base has an area of 56 x 56mm with cross-slot structure and 0.4 x 0.4mm thick pins through which the water can flow. Due to the extremely large cooling surface, the water can effectively absorb and dissipate heat from the cooler base. The Aurora design in conjunction with the 9 addressable digital aRGB LEDs offers many options for outstanding CPU water cooler illumination.
Eisstation DC-LT Reservoir & DC-LT 2 Pump
The Eisstation reservoir is extremely compact and flexible in use due to a variety of mounting options. Three G1/4" connections allow uncomplicated integration into the water loop. The additional G3/8" connection facilitates the filling of the reservoir. The DC-LT 2 pump is installed in the bottom of the Eisstation and is not visible from the outside. Due to its design, the pump is extremely quiet without having to sacrifice performance.
NexXxoS ST30 Full Copper 240mm Radiator V.2
All water-bearing parts and the cooling fins are made of pure copper. Thus, the NexXxoS ST30 achieves the highest thermal conductivity value of all radiators on the market and can easily dissipate extremely high waste heat. The radiator has two IN or OUT connections with G1/4" threads in the pre-chamber area. On the opposite side is a fill or vent port, which can be used to fill and drain the water loop.
Eiszyklon Aurora LUX PRO Digital RGB Fan (120x120x25mm)
The Eiszyklon Aurora LUX Pro fan offers a wide range of control as well as superior digital aRGB LED lighting. The individually controllable 5V aRGB LEDs coupled with the special design of the fan frame create unique lighting effects. The fan can be controlled from 800 to 2000 rpm via the 4-pin PWM connector. At 800 rpm, the fan is nearly silent, but still provides good airflow paired with high static pressure.
AlphaTube HF 13/10mm tubing & HF G1/4" quick connect coupling
The clear 13/10mm hose made of PVC offers comfortable handling when routing and connecting water cooling components. It has good routing and kinking characteristics and allows uncomplicated bridging of tight bend radii. The HF quick-connect coupling included in the scope of delivery allows easy integration of further components at a later date without having to drain or rebuild the water loop.
Eiszapfen 13/10mm G1/4" Connections
Thermal Paste & Coolant
All cables (aRGB, PWM) and controllers needed to use & control the pump, fan and aRGB lighting are included. The accessory package also includes important tools like hose cutter, filling bottle and an ATX 24-pin jumper. Thus, the construction of the custom loop can be started "out-of-the-box" immediately.
Intel: 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066 / 1851
AMD: AM2 / AM2+ / AM3 / AM3+ / AM4 / AM5
Technical data CPU cooler
Dimensions (L x W x H)73 x 63 x 21mm
Material coolernickel-plated copper
Material housingacrylic
Threads2 x G1/4“
Illumination3-Pin 5V, 9 digital aRGB LEDs
Max working temperature60°C
Pressure tested0,8 Bar
Technical data reservoir
Dimensions (L x W x H)102 x 82 x 85mm
Capacity250 ml
Material housingnylon, PMMA
Threads3x G1/4“ IT | 1x 3/8" IT
Illumination4x 5mm LED
Technical data pump
Dimensions (L x W x H)52 x 41 x 18mm
Materialsynthetic material, ceramics
Threads3-Pin JST
Speed2600 rpm
Operating voltage6-13,5V
Power consumption3.2W
Maximum pumping head1m
Maximum flow rate72L/h
Technical data radiator
Dimensions (L x W x H)271,5 x 124 x 30mm (+/- 3%)
Material threadsbrass
Threads4x G1/4" IN/OUT & 1x Fill-/Drainport G1/4"
Possible fan size120mm
Possible fan assembly2x one-sided / 4x both-sided
Fin density15
Technical data fan
Dimensions (L x W x H)120 x 120 x 25mm
Speed800 - 2000 RPM (+/- 10%)
Threads4-Pin PWM
Voltage12V DC
Current consumption4,8W
Static pressure2,0 mm H2O
Max. air flow104,49 m³/h
Speedometer signalyes
Illumination3-Pin 5V, 16 digital aRGB LEDs
Technical data tube
Dimensions (outer/inner)13/10mm
MaterialPVC
Length3m
Colorclear
Technical data 13/10mm G1/4" fittings
Materialbrass
Threads1x G1/4" OT | 1x tube connection 13/10mm
Technical data quick release coupling
Dimensions (L x D)60,3 x 26,1mm
Threads2x G1/4“ IT
Technical data coolant
Ingredientsosmose water(93,8%), glysofor L (4,2%), RHOBA KLA (2%)
Boiling point105°C
Freezing point-10°C
Packaging unit1L bottle
Colorclear (not UV-active)
Technical thermal grease
Viscosity (mPa. s)3.000.000
Specific Gravity (g/cm³)2,7
Thermal Conductivity (w/m-K)16
Temperature Stability (Degree Celcius)-50 ~ 200
Colorgray
63%
€1.58 * €4.28 *
€3.47 *
Alphacool fan cable 4-pin to 4-pin extension 30cm
€2.28 *
33%
€5.99 * €8.98 *
€37.98 *
