Alphacool Eisschicht Light Thermal Pad - 7W/mK 120x20x1.5mm
- Article no.: WAR
- EAN: 4250197128629
- Weight: 0,013 kg
The light version of the Alphacool ice layers with 7W/mK are the "small and weak" among the ice layers and yet strong enough. This means that all hardware components can now be installed easily and cleanly with thermal pads!
The Ice Layers Light are available in the 7W/mk power level in 0.5mm, 1mm and 1.5mm thicknesses. Perfect for compensating for height differences. Each thickness is also available in 100x100mm and 120x20mm (suitable for RAM coolers). These can be easily separated with scissors to individually adjust the right size for each component.
- Dimensions: 120 x 20 x 1.5mm
- 7W/mk
Scope of delivery
- 1x Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1.5mm
Flächenmaße: | 120 x 20mm |
Wärmeleitwert: | 7,0W/mk |
Befestigung: | leicht haftend |
Dicke: | 1,5mm |
