Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x2mm orange marked PE Bag (2 pieces)
  • 12197
  • 4250197121972
  • 0,01 kg
€2.19 *
Content: 18 cm² (€0.12 * / 1 cm²)
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 30 x 30 x 2mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
2x Alphacool thermal pad for NexXxoS GPX
Fastening: Slightly adhesive
Thickness: 2,0mm
Surface dimensions: 30 x 30mm
Thermal conductivity: 3,0W/mk
€6.99 *
WAR Alphacool Eisschicht Light Wärmeleitpad - 7W/mK 120x20x1,5mm
Alphacool Eisschicht Light thermal pad - 7W/mK 120x20x1,5mm
Content 24 cm² (€0.21 * / 1 cm²)
€4.97 *
WAR Alphacool Eisschicht Wärmeleitpad - 11W/mK 120x20x1mm - 2 Stück
€21.98 *
WZS Spritzflasche 250ml PE-LD
spray bottle 250ml PE-LD
€3.59 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x2mm
Content 16 cm² (€0.44 * / 1 cm²)
€6.99 *
Alphacool Core thermal pad Soft 6.2W/mk 40x40x0.5mm
Content 16 cm² (€0.25 * / 1 cm²)
€3.97 *
WÄM Alphacool Core Wärmeleitpad Soft 6.2W/mk 100x100x1mm
Alphacool Core thermal pad Soft 6.2W/mk 100x100x1mm
Content 100 cm² (€0.17 * / 1 cm²)
Alphacool Y-Splitter aRGB 3-Pin to 2x 3-Pin 15cm
€3.47 *
Alphacool Ice Layer Ultra Soft Thermal Pad 3W/mk 100x100x1.5mm
€24.98 *
€1.89 *
17%
S16 Alphacool Carbon HardTube 16mm 4x 80cm
Content 80 Zentimeter (€43.71 * / 100 Zentimeter)
€34.97 * €42.00 *
€29.98 *
21%
WÄM Alphacool Subzero Thermal grease 20g
€33.97 * €42.98 *
20%
WÄM Alphacool Subzero Thermal grease 1g
€3.97 * €4.97 *
