Alphacool Core Thermal Pad Soft 9W/mk 120x20x0,5mm
  • 13425
  • 4250197134255
  • 0,018 kg
Content: 24 cm² (€0.33 * / 1 cm²)
€4.28*
€69.98*
13420 Alphacool Core Thermal Pad Soft 9W/mk 40x40x0,5mm
€5.99*
13427 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1,5mm
€11.98*
Alphacool's performance thermal pad can be used to cool electronic components of all kinds where... more
Increased service life!
Versatile use!
Technical data thermal pad
Dimensions (L x W x H)120 x 20 x 0,5mm
Thermal Conductivity (ASTM D5470)9.0 W/mK (±10%)
Hardness (ASTM D2240)50 (Shore 00) (±15)
Working temperature-50 to ~180°C
Volume Resistance (ASTM D257)1×10¹² Ohm-m
Dielectric Breakdown Voltage (ASTM D149)≥8 KV/mm
Density (ASTM D792)3.2 g/cm³ (±10%)
Elongation (ASTM D412)40%
Flame Rating (UL 94)V-0
Colorpink
€0.98 *
€1.19 *
Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
Content 24 cm² (€0.42 * / 1 cm²)
Content 24 cm² (€0.50 * / 1 cm²)
€11.98 *
€34.98 *
Alphacool 4-Pin Molex to Lumberg 10cm
Content 10 Zentimeter (€44.80 * / 100 Zentimeter)
€4.48 *
WAC Alphacool Core 1 Silver
PSU Alphacool Core 60W PSU Extern
€29.98 *
Alphacool Core Thermal Pad Soft 9W/mk 40x40x2mm
Content 16 cm² (€0.62 * / 1 cm²)
Alphacool Core Thermal Pad Soft 9W/mk 100x100x2mm
Content 100 cm² (€0.37 * / 1 cm²)
€36.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1,5mm
Content 24 cm² (€0.33 * / 1 cm²)
Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
Content 24 cm² (€0.29 * / 1 cm²)
€6.99 *
Alphacool Core Thermal Pad Soft 6.2W/mk 100x100x0,5mm
Content 100 cm² (€0.12 * / 1 cm²)
€11.98 *
€4.48 *
€1.89 *
€5.99 *
WAGZ Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x2mm
Content 25 cm² (€0.28 * / 1 cm²)
€6.99 *
