Alphacool thermal pad for NexXxoS GPX 3W/mk 30x30x2mm orange marked PE Bag (2 pieces)
- Article no.: 12197
- EAN: 4250197121972
- Weight: 0,01 kg
Alphacool's new thermal pads with 3W/mk
Area of application:
Graphics card ram cooler
Mainboard voltage converter
North and/or Southbridge thanks to the excellent thermal conductivity
Color: grey
Dimensions (L x W x H): 30 x 30 x 2mm
Thermal conductivity: 3W/mk
electrically non-conductive
Scope of delivery
2x Alphacool thermal pad for NexXxoS GPX
Fastening: | Slightly adhesive |
Thickness: | 2,0mm |
Surface dimensions: | 30 x 30mm |
Thermal conductivity: | 3,0W/mk |
Liefertermin: in 2 - 3 Wochen
