  • 13037
  • 4250197130370
  • 0,004 kg
€1.89 *
Content: 1 Gramm (€1,890.00 * / 1000 Gramm)
13096 Alphacool Apex Thermal grease 20g
€46.98*
13408 Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x1mm
€3.58*
13413 Alphacool Core Thermal Pad Soft 6.2W/mk 120x20x1mm
€4.68*
13421 Alphacool Core Thermal Pad Soft 9W/mk 40x40x1mm
€4.78*
13426 Alphacool Core Thermal Pad Soft 9W/mk 120x20x1mm
€5.68*
The Alphacool Apex Thermal Grease is intended for all users who want to achieve the optimum... more
Application
Properties
Alphacool's Apex Thermal Grease has an extremely high thermal conductivity, making it one of the best performing thermal pastes on the market. Only liquid metal thermal pastes offer better thermal conductivity. The Apex Thermal Grease is delivered in a 1g applicator with screw cap. The Apex Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Range of uses
Volatilization Rate (24H@200°C)%less than 0.5
Density (g/cc)3.2 (Test method ASTM D792)
Viscosity (mPa.s)150~200*10³ (Test method ASTM D2196)
Continuous Using Temperature (°C)-40°C to 120°C
Breakdown Voltage (V/mil)250 (Test method ASTM D149)
Thermal Impedance (°C in 2/W)0.1 +/- 0.01 (Test method ASTM D5470)
Max. working pressure (psi)40
Quantity1g
Colorgray
Safety notes
  • Rinse gently with water for a few minutes.
  • In case of fire: Do not inhale explosion and fire gases.
21%
€33.97 * €42.98 *
22%
€46.98 * €59.98 *
Content 50 Gramm (€1,399.60 * / 1000 Gramm)
€69.98 *
€1.48 *
47%
€15.78 * €29.98 *
€6.99 *
38%
WÄM Alphacool Rise Ultra Soft Wärmeleitpad 7W/mk 50x50x3mm
Content 25 cm² (€0.20 * / 1 cm²)
€4.97 * €7.98 *
€38.98 *
