- Article no.: 13096
- EAN: 4250197130967
- Weight: 0,03 kg
Application
Properties
Alphacool's Apex Thermal Grease has an extremely high thermal conductivity, making it one of the best performing thermal pastes on the market. Only liquid metal thermal pastes offer better thermal conductivity. The Apex Thermal Grease is delivered in a 20g container with screw cap. The amount of thermal paste is sufficient for several applications and can be stored in the container protected from drying out. In addition, Apex Thermal Grease is non-conductive and non-caustic. If a small amount of paste is spilled during application, damage to the hardware is highly unlikely.
Range of uses
Technical data | |
Volatilization Rate (24H@200°C)% | less than 0.5 |
Density (g/cc) | 3.2 (Test method ASTM D792) |
Viscosity (mPa.s) | 150~200*10³ (Test method ASTM D2196) |
Continuous Using Temperature (°C) | -40°C to 120°C |
Breakdown Voltage (V/mil) | 250 (Test method ASTM D149) |
Thermal Impedance (°C in 2/W) | 0.1 +/- 0.01 (Test method ASTM D5470) |
Max. working pressure (psi) | 40 |
Color | gray |
Quantity | 20g |
Manufacturer: | Alphacool |
Contents: | 20 - 39g |
Viscosity: | 150~200*10³ |
Density: | 3,2 g/cm³ |
Color: | Gray |
- Do not get in eyes, on skin, or on clothing.
- Very toxic to aquatic organisms.
- Very toxic to aquatic organisms with long lasting effects.
- Rinse gently with water for a few minutes.
- Wash gently with plenty of soap and water.
- In case of fire: Do not inhale explosion and fire gases.
