  • 13093
  • 4250197130936
  • 10,43 kg
€399.98 *
€9.98*
Alphacool ES Orbiter 360 TS
€499.98*
€34.98*
The ES Orbiter Filling Station from Alphacool allows for easy and effective filling of water... more
The ES Orbiter Filling Station from Alphacool allows for easy and effective filling of water cooling systems. With the help of the two powerful pumps, the system to be filled is quickly vented. A high-performance filter ensures that the coolant is cleaned, making the ES Filling Station also ideal for cleaning cooling loops.
Efficient venting and filtering
The two built-in pumps in the ES Filling Station not only ensure redundancy, but also enable fast and reliable venting of the system to be filled. The installed filter ensures that no impurities enter the cooling system. Thanks to the filter, the Filling Station is also ideal for cleaning existing cooling circuits.
Easy handling
Filling the Alphacool ES Filling Station is effortless via the slightly raised G1 filling port. The illuminated inspection window allows easy monitoring of the fill level at any time and even in poorly lit environments. The integrated reservoir has a capacity of approx. 4500 ml. In addition, the Filling Station has a maintenance door for carrying out work such as changing filters.
Dimensions (L x W x H) 415,50 x 226,40 x 188,10mm
Material: Case Metal
Material: Reservoir Acrylic
Material: Tubes TPV (EPDM)
Approved liquids water, water/glycol mixture
Voltage 12V DC
Power consumption 39W
Approved water pressure 0,8bar
Max. pumping height 3,125m
Rate of flow 350l/h
Permitted operating temperature (industrial applications) 75°C
Water connections 2x G1/4“
Diameter filling port G1“
Volume reservoir approx. 4500ml
Color black
ANZ Alphacool Eiszapfen 2 Wege Kugelhahn G1/4 - White
Alphacool Eiszapfen 2-way ball valve G1/4 - White
Alphacool pull saw for acrylic/PETG pipes 35cm
Content 35 Zentimeter (€48.51 * / 100 Zentimeter)
Alphacool HardTube 16/13mm Acrylic (PMMA) Clear 80cm - Set of 4 (320cm)
€26.98 *
14%
Alphacool VPP655 - PWM - Single Edition
€74.98 * €86.73 *
33%
WACZ Alphacool Core AM5 Performance Kit
WAC Alphacool Core 1 Aurora White
€129.98 *
Liefertermin: in 5 - 6 Tagen
WAC Alphacool Core 1 White
€109.98 *
WAC Alphacool Core 1 Silver
€99.98 *
€99.98 *
