and Conditions Alphacool Eisbecher Helix 250mm reservoir - red
- Article no.: Terms
- EAN: 4250197153003
- Weight: 1,081 kg
- Available: There are more than 5 units available
The Alphacool Helix ice cream bowl impresses with its special helix look including elegant aluminum caps for the top and bottom. The 60mm version also offers a UV cathode tube which illuminates UV-reactive water from the inside.
Highlights
- Helix Optics
- Four color combinations
- Two diameter sizes with 50 and 60mm
- 60mm version with UV cathode tube
The Alphacool Eisbecher Helix 250 is a visual highlight of the Eisbecher family. The helix within the expansion tank creates a special effect that is reminiscent of a DNA strand and is therefore a real eye-catcher. In the middle of the expansion tank there is a UV cathode tube that is supplied with power via an adapter with a 4-pin Molex connector. If you use UV-reactive water, you create a strong glow from the inside of the tank. A very special effect that is sure to impress.
The base and lid are made entirely of acetal, but they are covered by aluminum caps for a classy look. The aluminum caps do not come into contact with the water, of course. The connection options are extensive, with three G1/4" threads in the lid and on the base. There are also two additional G1/4" connection options on the side of the base. This means that there are a variety of mounting positions to choose from.
You also get two different mounting sets. Firstly, the aluminum brackets known from the Eisbecher series, which are flush with the Eisbecher Helix at the top and bottom and offer the option of mounting the expansion tank on a radiator. The prerequisite for this is a 240 mm or 280 mm radiator or a larger equivalent such as a 360 mm or 420 mm radiator. As an alternative, clip brackets are also included, each of which can be attached to the housing with a screw. The Eisbecher Helix is simply clipped in here. This provides flexible options for mounting.
The Helix ice cream bowl is available in several color combinations. The lid and base as well as the Helix are each designed in a different color.
- Dimensions (HxD): 250 x 65mm
- Connection thread: 8x G1/4"
- Color Helix / aluminum caps: red / red
- UV cathode color: UV
- Cable length: approx. 27cm
- Capacity: 340ml
Scope of delivery
- 1x Alphacool Eisbecher Helix 250mm reservoir - red
- 1x UV cathode
- 1x adapter
- 2x aluminum brackets of the ice cream bowl series
- 2x retaining clips black
- Mounting material
- 6x locking screws
Material: | Acryl, Aluminium |
Behältertyp: | Röhrenbehälter 60mm |
Pumpenkompatibilität: | für Durchflusspumpen |
Pumpe vorinstalliert: | Nein |
Anschluss: | G1/4" Innengewinde |
Anzahl Anschlüsse: | 6 |
Fillport: | G1/4" Innengewinde |
Abmessungen: | 60 x 60 x 250mm |
LED Bohrungen: | nicht vorhanden |
Volumen: | 340ml |
Farbe: | transparent |
