Eheim compactOn pump 1000 230 volts
  • 1022220
  • 4011708001684
  • 0,52 kg
€30.47 *
The compact aquarium pumps for use underwater The EHEIM compactON aquarium pump is, true to... more
The EHEIM compactON aquarium pump is, true to its name, characterized by its compact design and can be used in a variety of ways thanks to the included accessory bag - the EHEIM compactON 2100-5000 pumps can also be converted for use outside of the water. Thanks to high-quality materials, it can also be used in sea water without any problems.
This pump is also suitable for use when ice bathing. It has sufficient flow to effectively cool the water before ice bathing in combination with a Hailea Chiller.
For even more flexibility, the flow rate can be adjusted on all models, except for the EHEIM compactON 5000.
Advantages of the EHEIM compactON
  • Successor to the compact and compact+ series
  • Fastening using robust suction cups
  • Including accessories such as suction baskets and threaded connectors
  • Quiet running due to ceramic bearings (EHEIM compactON 2100 and EHEIM compactON 3000)
  • High pumping performance with low power consumption
  • compactON 5000 as electronic version for even more efficiency
Technical data:
  • Pump capacity per hour at 50 Hz: 1000 l
  • Discharge head at 50 Hz approx. (H max): 1.4 m
  • Power consumption at 50 Hz: from 15 watts
  • Dimensions (WxHxD): 47 x 79 x 73mm
  • Hose Ø pressure side: 16mm
  • Voltage 230 volts
  • Frequency 50 Hz
  • Power plug EUR
  • Freshwater yes
  • Sea water yes
Multilingual user manual (DE, FR, EN)
Multilingual user manual (ES, IT, PT, NL)
WAC Alphacool Core 1 LT Aurora Acryl
Alphacool Core 1 LT Aurora Acrylic
€84.98 *
Leak Testing Tool incl. Pump
€36.98 *
S16 Schlauch PVC 16/12mm (1/2"ID) Clear Meterware
€2.69 *
