Alphacool Eiskamm Alu X4 Flat - 4mm black - 4 pcs
  • 24767
  • 4250197247672
  • 0,004 kg
€2.09 * €5.02 * (58.37% Saved)
What is it? The Alphacool Eiskamm is the perfect cable comb for laying cables neatly and... more
What is it?
The Alphacool Eiskamm is the perfect cable comb for laying cables neatly and getting the best look for your system.
Highlights
  • Made of aluminium
  • More stable than acrylic
  • Fits all standard cable types
  • Four different colours
The Alphacool Aluminium Eiskamm is the optimal solution for laying cables neatly and getting the best look for your system. The Eiskamm cable combs, cut from aluminium tubes, are much stabler than acrylic versions. To prevent damage to the sleeves, all corners are rounded off - sharp corners that can cut into the sleeve are history. Of course, Alphacool offers several sizes for every cable type, from SATA cables to 8-pin right up to 24-pin ATX cables, all available in different colours.
Technical Details
  • Material: Aluminum
  • Variant: Alu X4 Flat
  • Dimensions: 19 x 5,5 x 2,5mm
  • Colour: Black
Scope of Delivery
  • Alphacool Eiskamm Alu X4 Flat - 4mm black - 4 pieces
Datasheet
Mounting manual
PUZ Alphacool Klettmatte zur Pumpenbefestigung
Alphacool Velcro for pump mounting 107x85 mm
€3.48 *
ZK Stromversorgungskupplung für 4Pol
€1.69 *
Alphacool Eiskamm X12 - 3mm clear - 4 pcs
€1.19 *
Alphacool Eiskamm X14 - 3mm clear - 4 pcs
€1.99 * €4.49 *
KAB Alphacool Eiskamm Alu X16 - 4mm black - 4 Stück EOL
Alphacool Eiskamm Alu X16 - 4mm black - 4 pcs
€5.49 * €9.94 *
KAB Alphacool Eiskamm Alu X5 Flat - 4mm black - 4 Stück EOL
€2.09 * €5.02 *
KAB Alphacool Eiskamm Alu X24 - 4mm black - 2 Stück EOL
Alphacool Eiskamm Alu X24 - 4mm black - 2 pcs
€3.19 * €5.02 *
KAB Alphacool Eiskamm Alu X12 - 4mm black - 4 Stück EOL
Alphacool Eiskamm Alu X12 - 4mm black - 4 pcs
€4.29 * €8.00 *
Liefertermin: in 10 - 11 Tagen
KAB Alphacool Eiskamm Alu X8 - 4mm black - 4 Stück
Alphacool Eiskamm Alu X8 - 4mm black - 4 pcs
€3.28 * €6.96 *
KAB Alphacool Eiskamm Alu X4 - 4mm black - 4 Stück EOL
Alphacool Eiskamm Alu X4 - 4mm black - 4 pcs
€3.19 * €5.02 *
WAK Alphacool Core RX 7900XTX/XT Taichi - Phantom mit Backplate
Alphacool Core RX 7900XTX/XT Taichi - Phantom with Backplate
€199.98 *
Alphacool Core Thermal Pad Soft 6.2W/mk 40x40x0,5mm
€3.97 *
€4.48 *
WAK Alphacool MCX 2x Verteiler mit 1m 5/3mm Schlauch
Alphacool MCX 2x distributor with 1m 5/3mm hose
Content 4 Gramm (€3,995.00 * / 1000 Gramm)
Content 500 Milliliter (€9.96 * / 1000 Milliliter)
€4.98 *
ANS Alphacool Apex Fillport - chrome
S16 Alphacool Carbon HardTube 16mm 4x 80cm
Content 80 Zentimeter (€62.48 * / 100 Zentimeter)
€49.98 *
WAH Alphacool HDX Apex Acryl aRGB M.2 2280 SSD Kühler
Alphacool HDX Apex Acrylic aRGB M.2 2280 SSD Cooler
Alphacool Apex Soft Thermal Pad 11W/mk 100x100x1mm
Content 100 cm² (€0.36 * / 1 cm²)
ANF Alphacool ES D-Plug 20mm G1/4 AG auf G1/4 AG - Deep Black
€7.28 *
Content 25 cm² (€0.48 * / 1 cm²)
€11.98 *
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
Liefertermin: in 8 - 9 Wochen
€44.98 *
SEN Alphacool Core Temperatursensor mit C/F Display
Alphacool Core Temperature Sensor with C/F Display
WZS Alphacool Core Befülltrichter
Alphacool Core filling funnel
€2.98 *
RAB Alphacool NexXxoS Nova 1080 mm Lüfterbox - Black
Alphacool NexXxoS Nova 1080 mm fan housing - Black
Alphacool Temperature Sensor Square Acetal
Alphacool Eisrohr 14/11mm PETG HardTube 80cm - 4pcs
€23.98 *
WAGZ Alphacool Eisblock Aurora Terminal flat straight - Acetal
