Alphacool Core Geforce RTX 5090 EPIC-X with Backplate
- Article no.: 14739
- EAN: 4250197147392
- Weight: 1,754 kg
- PNY GeForce RTX™ 5090 ARGB EPIC-X RGB™ Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5090 ARGB EPIC-X RGB™ Triple Fan GPU
- PNY GeForce RTX™ 5090 Overclocked Triple Fan GPU
- PNY GeForce RTX™ 5090 Triple Fan GPU
| Technical data cooler | |
| Dimensions total (L x W x H) | 218,40 x 148,57 x 34,38mm |
| Material terminal | Acetal |
| Pressure tested | 0,8 bar |
| Threads | 4 x G1/4" |
| Number of digital aRGB LEDs | 9 |
| Color | transparent |
| Dimensions (L x W x H) | 218,40 x 120,00 x 6,00mm |
| Thick backplate without spacers | 3mm |
| Material | Aluminium |
Delivery date: in 5 - 6 weeks
