Alphacool Eisblock Aurora Acryl GPX-N RTX 3090TI Founders Edition with Backplate
  • 13056
  • 4250197130561
  • 1,5 kg
€49.99 * €159.98 * (68.75% Saved)
€19.98*
€18.98*
€10.98*
15393 Alphacool Core 100 Aurora reservoir D5/VPP Acetal/Acryl
€51.98*
The Alphacool Eisblock Aurora Acrylic GPX graphics card water cooler with backplate combines... more
More performance!
During the development of the Eisblock Aurora Acryl GPX graphics card water cooler, emphasis was naturally placed on increasing performance. First, the cooler was brought closer to the individual components by reducing the thickness of the heat conducting pads. Next, the nickel-plated copper block was also made thinner. Step 3 involves the constant optimisation of the water flow within the cooler. The result: All important components such as voltage converters and RAM are cooled much better and more effectively by the water and the cooling performance increases significantly.
Brilliant design!
Copper or aluminium?
Alphacool only uses copper in its water coolers. In the case of the Eisblock Aurora Acryl GPX, the copper is nickel-plated. Compared to the previous models, however, Alphacool has once again improved the type of nickel plating, which has significantly increased the acid resistance. This should prevent the nickel plating from flaking off. Why does Alphacool use copper instead of aluminium? Copper has almost twice the thermal conductivity of aluminium and is therefore clearly the better material for water cooling.
Other special features
- Inno3D GEFORCE RTX 3090 TI ICHILL FROSTBITE
- Inno3D GEFORCE RTX 3090 TI X3 OC
- Nvidia 3090 Ti Founders Edition
Technical data cooler
L x W x H220.5 x 146.40 x 23.35 mm
Material cooler topacrylic
Threads4 x G 1/4
Thickness cooling fins0.6 mm
Illuminationdigital aRGB LEDs
Power digital aRGB LEDs5 V
Number of digital aRGB LEDs11
Pressure tested0.8 bar
Technical data backplate
L x W x H220 x 121.4 x 6 mm
Materialaluminium
€4.38 *
and Conditions Alphacool Eisstation DC-LT - Solo Top
€26.98 *
€6.99 *
