Alphacool Eiszapfen PRO 16mm HardTube Fitting G1/4 - Chrome
  • 17472
  • 4250197174725
  • 0,056 kg
€10.98*
18444 Alphacool HardTube 16/13mm Acryl clear 80cm - 4pcs
€28.98*
S16 Alphacool Ice Tube 16/13mm Acrylic (PMMA) HardTube Satin 80cm - Set of 4 (320cm)
€38.98*
SZ Alphacool Acrylic Tube Double Bending Tool 12-14mm and 16mm - Black
€17.98*
ANS Alphacool Eiszapfen PRO 16mm HardTube Fitting G1/4 - Chrome Sixpack
€39.98*
€1.98*
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the... more
The new Eiszapfen PRO HardTube fittings from Alphacool are a further development of the well-known Eiszapfen. When developing the fittings, Alphacool focused specifically on a specific problem: the deformation of PETG HardTubes at high temperatures. These can deform at as little as 60°C. Although such a temperature is rarely reached, it can still occur. The Eiszapfen PRO prevent this problem from the outset and hold the tubes in position.
Technical details:
  • Material: Brass
  • Color: Chrome
  • Diameter: 26mm
  • Height: 23mm
  • Thread: G1/4"
  • Thread length: 5 mm
  • HardTube Size: 16 mm
  • Compatibility: PETG, acrylic, brass and glass tubes
  • Weight: 0.042kg
  • Scope of delivery: 1x Alphacool Eiszapfen PRO 16mm HardTube Fitting G1/4 - Chrome
€28.98 *
€38.98 *
€26.98 *
S16 Alphacool HardTube 16/11mm Borosilikatglas 40cm
Alphacool HardTube 16/11mm borosilicate glass 40cm
Content 40 Zentimeter (€29.95 * / 100 Zentimeter)
€11.98 *
